-SISTEMUL ANTIBALANS REDUCE BALANSUL LATERAL NU SI CEL VERTICAL.SISTEMUL CAUTA SA REDUCA AMPLIFICAREA BALANSULUI REZULTAT DIN OCOLIREA BRUSCA A UNUI OBSTACOL.LA O ASTFEL DE MANEVRA RULOTA(FARA ANTIBALANS SI MAI GRAV SI FARA AMORTIZOARE) TINDE SA INTRE INTR-UN BALANS LATERAL CARE ADAUGAT LA MANEVRAREA BRUSCA A VOLANULUI STANGA-DREAPTA PENTRU REDRESAREA MASINII POATE DUCE LA INTRAREA IN DERAPAJ A RULOTEI SI IMPLICIT A INTREGULUI ANSAMBLU AUTO-RULOTA CU EFECTE DINTRE CELE MAI NEPLACUTE(RASTURNARE SAU DERAPAJ).
-SISTEMUL ANTIBALANS SE POATE PROBA ASTFEL:SE MONTEAZA FARA RULOTA SI NEGRESAT PE NUCA(SUNT EXCLUSE TOTAL CARLIGELE FACUTE ARTIZANAL CARE NU AU NICI FORMA NICI DIMENSIUNILE ORIGINALE).SISTEMUL ASTFEL MONTAT NU TREBUIE SA POATA FI MISCAT LATERAL PRIN FORTZA MAINII.EL POATE FI MISCAT DOAR IN PLAN VERTICAL(SUS-JOS).
-UNELE SISTEME INDICA PE LANGA CUPLAREA CORECTA LA NUCA SI GRADUL DE UZURA AL PASTILELOR DE CONTACT.
-DEASEMENEA PRIN CONSTRUCTIE SISTEMUL BENEFICIAZA DE DOUA SISTEME DE SIGURANTZA EL NEPUTAND FI DECUPLAT DECAT DUPA CE AMBELE SISTEME SUNT DECUPLATE.
-LA BUNA FUNCTIONARE A SISTEMULUI CONCURA SI PISTONUL SISTEMULUI DE FRANARE CU CELE DOUA BUCSI DIN TEFLON CARE SE GRESEAZA PERMANENT.
-IN CAZUL IN CARE SISTEMUL "SCATAIE"LA VIRAJE SI DENIVELARI TREBUIE CURATATE PASTILELE DE CONTACT CU UN SMIRGHEL FOARTE FIN.
RECOMAND TUTUROR MONTAREA DE ASTFEL DE SISTEME SIMILARE CUMVA CU A.B.S. ul DE PE MASINI.(
WWW.RULOTA.RO)
DRUM BUN SI IN SIGURANTZA TUTUROR!
