Vand trusa surubelnite Noua
Terecoasa Adrian
Oras: Busteni
Data nasterii: 24 Mai 1979
Mesaj de Terecoasa Adrian »
Trusa surubelnite noua cumparata din S.U.A.
100%Brand New
Brand:Unbranded
Material:Metal
Case Material:Plastic
Case Color:Black
Item:Bit Set
Features:Supplied ina blow mould case witsh display sleeve
Application:Indoors/Outdoors
Occasion:Casual
Ideal for:For home DIY
Case Dim.:36x27x6,5cm
Setul contine:
4 Plains lot cabinet patern screwdrivers size:3x75mm,5x75mm,6x100mm,8x150mm.
4 Cross slot cabinet patern screwdrivers No.,0,1,2 and 3
2 PZ TYPE Cabinet patern screwdrivers No.1 and 2.
4Plain slot precision screwdrivers 50mm
Long size:1,5;2,0;2,5;and3,0mm.
2 Cross slot precision screwdrivers 50mm long No.00 and 0,0.
5 draper TX-STAR precision screw drivers 50mm long size:T8,T9,T10,T15 and T20
Gs approved mains tester.
1/4\'' magnetic bit helding driver.
5x1/4\'' plain slot insert bits size 3,4,5,6 and 7mm.
4x1/4\''cross slot insert bits No.0-3.
4x1/4\''PZ type insert bits No.0-3.
6x1/4\''draper TX-STAR BITS T10-T40.
6X1/4\'' hexagon insertbits size 2-6mm.
9x1/4\''sockets size:5,6,7,8,9,10,11,12 and 13mm.
9x1/4\''sockets size:3/16;7/32;3/8;1/4;5/16;11/32;7/16;15/32and1/2\''AF.
245mm(approx.)flexible extension shaft magnetic pick-up tool.
1/4\''(M)X1/4\''(F)bit holder
1/4\''(M)X1/4\''(F)socket adaptor
Quantity:1pcs.
Package contents:1xbit set
Ideal for your home using and building or setting something.
Lightweight with the durable material bring more fun to your life.
Pret:400Ron
Terecoasa Adrian
Oras: Busteni
Re: Vand trusa surubelnite Noua
Reducere de pret la 350Ron.
Terecoasa Adrian
Oras: Busteni
S-a vandut,se poate inchide topicul.Va multumesc pentru gazduire!
:topic_closed:
