Vand Nikon D300s
Adrian.Apreotesei
Oras: Bacau
Data nasterii: 10 Mai 1977
Vand Nikon D300s
Mesaj de Adrian.Apreotesei »
Ofer spre vanzare;
- un aparat foto DSLR Nikon D300S - body
- obiectiv Tamron AF-S SP 17-50mm f/2.8 XR Di II LD Aspherical IF - montura Nikon
Nikon D300 S
• senzor: 23.6 x 15.8 mm CMOS, format DX, 12.3 MPx efectivi
- aspect 3:2
- rezolutie maxima imagine: 4288 x 2848 px
- rezolutie maxima filmare: 1280 x 720 @ 24 fps
- format fisiere: Jpeg, AVI, NEF (12/14 bit), TIFF
- functie de curatare automata a prafului
- procesor de imagine: Expeed 14 bit
- factor crop: 1.5x (format DX)
• obiective compatibile: DX-AF, D-/G-type AF, AF, AI-P, Non-CPU AI
• auto-focus Multi-CAM 3500DX
- 51 de puncte (15 in cruce)
- plaja de lucru: -1 to +19 EV @ISO 100
- detectarea contrastului in mod LiveView
- moduri focus: Single Servo AF , Continuous Servo AF [C], Manual focus [M], Focus Tracking
- zone AF: Single point AF, Dynamic Area AF, Automatic-area AF
- focus lock
- lampa asistenta AF integrata, raza de operare 0.5 - 3 m
• moduri de expunere: Program Auto [P], Shutter-Priority Auto , Aperture-Priority Auto [A], Manual [M]
- masurarea luminii: TTL folosind un senzor 1005-pixel RGB, 3D Color Matrix Metering II, Center-weighted (75% la centru, diametrul 6, 8, 10, or 13 mm), Spot (aprox. 3 mm diametrul)
- plaja de masurare: 0 - 20EV
- compensarea expunerii: +/- 5EV
- blocarea expunerii
- bracketing expunere: 2-9 cadre, in pasi de 1/3, 1/2 sau 1EV
- sensibilitate ISO: normal 200-3200, extins 100-6400
- shutter: electronic, vertical
- timp de expunere: Bulb, 30-1/8000s
- sincronizare flash: 1/250s sau 1/320s cu GN redus
• balans de alb: Auto, preseturi, manual, Kelvin (2500 - 10000K), Bracketing
- spatiu de culoare: sRGB, AdobeRGB
• vizor: optic, cu pentaprisma
- ajustarea dioptriei: -2/+1
- Eyepoint: 19.5 mm
- acoperire: 100%
- magnificare: ~0.94x cu 50 mm f/1.4
- ecran de focus: B-type BrightView Clear Matte Screen II
• LCD: 3.0 " TFT, 920.000 pixeli, acoperire 100%, vedere din unghi de 170°
- functie LiveView, cu AF
• fotografiere in rafala: pana la 7 fps cu bateria standard, pana la 8 fps cu grip MB-D10
- moduri fotografiere: Single frame, Continuu low, Continuu High, Silentios, Declansare temporizata (2/5/10/20s), Mirror lock-up
• flash: control TTL, 1,005-pixel RGB sensor
- moduri sincronizare: Front-curtain Sync (normal), Red-Eye Reduction, Red-Eye Reduction with Slow Sync, Slow Sync, Rear-curtain Sync
- numar director: 17 @ ISO200
- patina pentru flash extern (Nikon SBxxx sau compatibile)
- mufa conectare flash: ISO 519
- compensare flash: -3 / +1 EV, in pasi de 1/3,1/2 sau 1EV
- control wireless flashuri: suportat cu flashul integrat, Speedlight SB-900, SB-800 sau SU-800 ca si commander si SB-900, SB-800, SB-600 sau SB-R200 ca si slave
• conectivitate: USB 2.0 Hi-Speed Mini-B, HDMI Mini tip C, terminal cu 10 pini pt telecomanda sau GPS (GP-1 cu cablu adaptor MC-35), terminal PC-Sync
- stocare: carduri SD/SDHC/CF TypeI, compatibil UDMA
- alimentare: Lithium-Ion EN-EL3e (7.4 V, 1500 mAh)
• dimensiuni: 147 x 114 x 74 mm
- greutate: 918g (cu baterie)
PRET :
Kit : 3200 ron
Body : 2600 ron
Obiectiv: 800 ron
Este cumparat in dec 2012, inca mai are garantie 1 an. Are 7444 cadre.
